01-13-2010, 08:23 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>>>>> j 132 unlock ok infinity-box<<<<<<< module v1.38 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20100113-122135.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 1 min 2 sec Remove/Install battery now ! |
The Following User Says Thank You to shahid41 For This Useful Post: |
01-18-2010, 08:20 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Kushtia,Bangladesh
Member: 597569 Status: Offline Sonork: 100.1593870 Thanks Meter: 271 | Sony Ericsson J132 unlock done by infinity-box Use AT106 C2500 infinity box cable COM4 [VCP1] selected module v1.38 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20100118-130100.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 1 min 15 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to anis_rainbow For This Useful Post: |
01-23-2010, 11:57 | #7 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Kazakhstan Age: 41
Member: 4374 Status: Offline Thanks Meter: 9 | I have this with J132 COM15 [Serial2] selected Модуль v1.38 Модель: Sony-Ericsson-J132 улучшенный метод определения флеша включен Действие: разблокировка Проверка данных, ждите... Бутинг ... Аппарат должен быть выключен ! Нажмите кнопку включения ! rom version: 0502 Connecting... booting... finalizing... Бутинг fail ошибка: сбой операции ! Закончено, потребовалось времени: 47 sec Отключите/подключите батарею ! Only SeTool? |
vodaphone 226 unlock ok infinity-box | shahid41 | Infinity-Box | 1 | 09-05-2009 05:43 |
>>>>>>> 1680 unlock ok universalbox<<<<<<< | shahid41 | Universalbox | 0 | 08-20-2009 10:43 |
sony ericsson j 132 unlock ok by setool | aleem26 | SETool2 | 4 | 08-18-2009 13:32 |
sony ericsson j 132 unlock ok by setool | aleem26 | SETool2 | 1 | 11-24-2008 14:24 |
