11-08-2009, 14:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 815644 Status: Offline Thanks Meter: 56 | kp 170 unlock success ihad unlock kp170 with infinity. i slect kp215 model and format it. now my set is unlock but phone imei gone to 0000000000000. loner is given below COM3 [VCP0] selected module v1.39 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 354789654125426 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354789654125426_LG-KP215_20091109-062850.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 354789654125426 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 64 sec Remove/Install battery now |
11-24-2009, 18:05 | #7 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 408058 Status: Offline Thanks Meter: 371 | kp 170 unlock thin re COM3 [VCP0] selected module v1.39 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP215_20091124-215547.B1E.bin .................................................. .............. reading _eeprom-ffs_350305260000001... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_350305260000001_LG-KP215_20091124-215827.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 222 sec Remove/Install battery now ! |
12-03-2009, 23:32 | #8 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Jamaica Age: 41
Member: 162707 Status: Offline Thanks Meter: 66 | Hi after unlock i can't get any signal. Can you please help me? The imei is all zeros, can't infinity repair the imei? Am awaiting your speedy response. Venom |
kp 170 unlock successfully with vygis | imran_mobi | VygisToolbox | 22 | 05-30-2009 13:05 |
kp 170 unlock successfully. | shamshad quresh | VygisToolbox | 0 | 05-21-2009 06:10 |
kp 170 unlock ok dut phone still locked look here | shahinahmed007 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 0 | 04-10-2009 13:57 |
kp 170 unlock done but cannot unlock? | ikram tabassum1 | HWK | 3 | 04-03-2009 16:40 |
kp 170 unlock successfully with vygis | imran_mobi | VygisToolbox | 0 | 02-19-2009 13:02 |
