11-06-2010, 21:50 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | KP-199 dead after flash MY LG KP-199 DEAD AFTER FULL FLASH WITH INFINITY PLZ HELLP ME INFINTI TEAM I TRY TO DOWNLOAD ALL FIRMWARE FROM INFINITY SUPPORT ARIA OR FLASH WITH ALL VER: BUT SET IS FULLY DEAD AND NOT ON AFTER FULL FLASHING WITH ALL FIRMWARE PLZ HELLP ME . HERE IS LOG FLASHING : Code: COM45 [VCP0] selected module v3.64 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware KP199-00-V10a-404-XX-MAY-02-2008_KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-001-R1A_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:4BB2:4DA7 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 7AC8645F rom info ver: 04 sw version: KP199_PCB01_GPRS_MT6226_S01.7S7339IN00-003-R1G.BIN project-id: 7S7339IN00-003-R1G, EFF582E5 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98000300000001:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 54 sec Remove/Install battery now ! Code: COM45 [VCP0] selected module v3.64 Device: LG-KP199 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:4BB2:4DA7 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required rom info detection finished device-id: 7AC8645F rom info ver: 04 sw version: KP199_PCB01_GPRS_MT6226_S01.7S7339SA00-001-R1A.BIN project-id: 7S7339SA00-001-R1A, AD93639C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done Finished, time used: 40 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! during long time (up to 1 min) BUT SET NOT ON . NOTE :I TRY TO FLASH WITH KP-220 FIRMWERE SET ON AFTER FLASHING BUT KEYPAD IS NOT WORK PROPERLY |
11-07-2010, 12:34 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! which was initial phone problem? and which was original software version? if you are not sure now, please open with any text editor file named operatio.log (you can find it in same directory where China Miracle is). search for date/time of first operation of this phone and copy>paste this log here. we will check which flash file to advise you |
11-07-2010, 19:27 | #4 (permalink) | |
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | Quote:
how to flash this phone what is reason dead after flshing ...plz guide me step by step product suppoter .. | |
11-08-2010, 10:19 | #6 (permalink) | |
my problem solve .. i no need u r help tc | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
