05-22-2008, 09:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | << KG110 sim registration failed : Solved >> 1. Full flashed the phone using file - KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M.bin 2. Tick firmware (Code) and smart write options only. And u will go voila.. Thanks Infinity Team..... COM4 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352691019147339 current otp imei: 352691019147339 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35269101914733 9_LG KG110_20080522-140530.B1E.bin ........ version: 404-XXV10a91KG110P40FL Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 384 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to zeel_zeel For This Useful Post: |
01-16-2009, 19:40 | #5 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 754267 Status: Offline Thanks Meter: 116 | i request to infinity box and all infinity users plz attach this full flash file of lg KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M.bin on this page. thanks in advance |
01-17-2009, 15:09 | #10 (permalink) |
Member: 754267 Status: Offline Thanks Meter: 116 | Today i repair lg kg110 sim card rigestration fail sucessfully COM5 [VCP0] selected Device: LG-KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352691010123453 current otp imei: 354701019701817 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691010123453_LG-KG110_20090117-055851.B1E.bin ........ version: 404-XXV10d91KG110P40FL Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 58 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to ghazishah For This Useful Post: |
01-17-2009, 15:23 | #11 (permalink) |
Member: 754267 Status: Offline Thanks Meter: 116 | Dear infinity team i hv lg ke 770 its imei is cplc block i want 2 change its imei plz tell me urgent how can i rebuild its imei on infinity box plz send me some method Thanks in advance |
02-02-2009, 12:54 | #15 (permalink) |
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | One more phone repaired by the same way >>>>> COM4 [VCP0] selected module v1.36 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 352691011364841 current otp imei: 352691011364841 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691011364841_LG-KG110_20090202-171222.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 425 sec Remove/Install battery now ! |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
6280 sim registration failed but sim ic ok | luyanda | Nokia Hardware & Hardware Repair | 10 | 01-09-2010 07:01 |
3510ì Sim Registration Failed! Help! | Maurone | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 01-07-2005 14:23 |
sim registration failed | jonzey | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-08-2003 23:20 |
3310 says sim registration failed | junoon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 12-16-2002 10:47 |
8310 Sim registration failed after wrong unlock | tyro628 | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 11-09-2002 19:03 |
