04-05-2009, 10:10 | #1 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | ...:::KP105 Blinking solution done:::... Only write good eeprom ..... Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20090406-020459.B1E.bin COM7 [VCP0] selected module v1.60 Device: LG-KP105 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL KP105 KP100 P16 00 ARB V10b ARB-XX DEC-27-2007 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20090406-020459.B1E.bin loading data... data loaded imei: 35996001198230500 reading eeprom-security_35996001198230500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-security_35996001198230500_20090406-020500.B1E.bin reading eeprom-complete_35996001198230500... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-complete_35996001198230500_20090406-020501.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 15 sec Remove/Install battery now ! ...:::S@JID:::... |
The Following 8 Users Say Thank You to sajidashraf For This Useful Post: |
04-05-2009, 19:55 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
04-13-2009, 07:17 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | I have Lg kp105 but it can't detect through infinity,vygis may be this 1 is new version with new pinout any idea any solution |
The Following User Says Thank You to Rise For This Useful Post: |
04-13-2009, 08:13 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | bro check your cable and phone conecters also ...... there is no connection of new ver with pinouts .......pinouts are same for kp105 for every ver |
The Following User Says Thank You to zeerik For This Useful Post: |
04-13-2009, 09:05 | #6 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | .::thanks man good info and great sharing very useful info::. |
The Following User Says Thank You to azeem781986 For This Useful Post: |
04-13-2009, 10:45 | #7 (permalink) |
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | Yes it have done by Vygis but infinity can't detect with kg800 cable because kp501 support ke500 cable pinout |
04-19-2009, 20:49 | #8 (permalink) | |
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | Quote:
http://rapidshare.com/files/215785708/kp320.rar.html ...:::S@JID:::... | |
The Following User Says Thank You to sajidashraf For This Useful Post: |
04-19-2009, 20:51 | #9 (permalink) | |
06-05-2010, 10:57 | #14 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | Done many times with flashing eeprom_repair and after sp-unlock with airtel mode. |
The Following User Says Thank You to ZubairArain For This Useful Post: |
N-Gage No radio after 4 blinks solution | jusluke | WD2 & APE (Symbian Phones) | 8 | 01-07-2010 05:00 |
7650 4x blink solution needed | douda | WD2 & APE (Symbian Phones) | 14 | 08-23-2004 07:11 |
3650 4x Blinks Solution! Free To All! | speed | WD2 & APE (Symbian Phones) | 18 | 08-03-2004 16:31 |
a50 only blinking solution!!!!!!! | infogsm | x1x to x45/x50 | 6 | 07-05-2003 16:42 |
