09-28-2009, 11:15 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: BRADFORD ENGLAND
Member: 309581 Status: Offline Thanks Meter: 16 | rome zte g-231 unlocking error please help module v2.86 Action: read codes unlock method: read codes Model: Aiko-17G Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 72 byte(s) read imei: D445B413000000 connection Ok 77 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 32 byte(s) read error: source data size is less than expected error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! |
09-29-2009, 09:58 | #2 (permalink) | |
Please, select correct model and try to unlock phone again. | |
10-02-2009, 17:08 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | COM10 [VCP2] selected module v2.86 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903018253 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 31 sec Remove/Install battery now ! |
The Following User Says Thank You to Y2ksalman For This Useful Post: |
10-06-2009, 09:25 | #4 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 437422 Status: Offline Thanks Meter: 37 | COM7 [VCP2] selected module v2.90 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35547302600000 connection Ok 186 byte(s) read reading data... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to musmanm For This Useful Post: |
10-24-2009, 11:50 | #5 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | COM4 [VCP0] selected module v2.91 Action: unlock unlock method: smart fast Model: ZTE-231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 44 byte(s) read connection Ok 157 byte(s) read reading data... reading data #2... reading data #3... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! |
10-24-2009, 19:54 | #6 (permalink) | |
ZTE-R231 and ZTE-231 is a different models ! You must select correct model. | |
11-18-2009, 06:41 | #7 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 255638 Status: Offline Thanks Meter: 10 | This is log please follow COM14 [VCP1] selected module v2.93 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 9600 autodetect error: boot phase #2/1 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 3 sec Remove/Install battery now ! |
11-18-2009, 11:30 | #8 (permalink) | |
It's a cable problem for sure. Please, double check your cable. | |
11-22-2009, 11:37 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 3 wires should be used: Rx/Tx/Gnd If you still have a problems with initial connection, please, double check your cable. Probably you need to swap rx <-> tx wires |
11-22-2009, 14:29 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
12-01-2009, 10:22 | #13 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 49
Member: 232607 Status: Offline Sonork: 100.1585040 Thanks Meter: 260 | COM4 [VCP0] selected module v2.94 Action: unlock unlock method: smart fast Model: ZTE-R231 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ORANGE_ENG_EN_P107A1V1.0.4B02 Version: 08BZTENJ35_OG_08B 80 byte(s) read imei: 35424903003311 connection Ok 186 byte(s) read reading data... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 100 sec Remove/Install battery now ! thanx infinity team |
The Following User Says Thank You to zahid_gsm For This Useful Post: |
12-01-2009, 16:45 | #15 (permalink) |
M702iG unlocking error please help..... | carlluvjo | Smart-Clip | 1 | 03-25-2008 10:38 |
Nokia 6125 Unlock Error... Please Help... | kitcat | J.A.F. V-SPEC | 1 | 02-05-2008 17:44 |
E65 unlock error!!! please help... | wildtiger | J.A.F. V-SPEC | 3 | 12-09-2007 16:53 |
Ku790 Unlock Error Please Help | feritk | ULT PRO | 11 | 09-18-2007 10:33 |
7290 unlock error.please help | GOODNESS | FuriousGold | 1 | 09-06-2007 16:40 |
