Old 01-23-2010, 10:29   #1 (permalink)
shahzadthe1's Avatar
Member: 541117
Sonork: .::100.1586906::.
Thanks Meter: 173
why touch calibration not working
is there any mistake pls infinity team have a look
COM6 [VCP0] selected
module  v3.06
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.G250_M1_PCB5_DSIM_ST32T4_V01A__fullflash_20100120-151223.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4B03:0002
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 1 min 29 sec
Remove/Install battery now !
Old 01-23-2010, 12:05   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It may be that phone has damaged eeeprom/ffs.
1. make "complete" format
2. power-on phone
3. power-off phone
repeat calibration again
Old 01-23-2010, 14:07   #3 (permalink)
Member: 541117
Thanks Meter: 173
already tried that bt not success
any other way to repair eeprom/ffs without formatting ffs ??
BR.,
Old 01-23-2010, 15:40   #4 (permalink)
Member: 130995
Hello,
Did you tried to press and HOLD phone "Power" button more long time during boot process ?
It's need to hold Power button long time.
Also, what cable you have used ?
Do you use ordinary RJ45 cable or PinFinder ?
Old 01-23-2010, 16:26   #5 (permalink)
Member: 541117
Thanks Meter: 173
yes sir, i pressed power button for long time
an m using pinfinder
BR.,
Old 01-23-2010, 18:23   #6 (permalink)
Member: 130995
BR.,
Please, try to make PinFinder "Selftest" procedure (see PinFinder manual).
Is it possible to Power-On phone from PinFinder ?
Old 01-23-2010, 18:51   #7 (permalink)
Member: 541117
Thanks Meter: 173
thnx , i'll study this "Selftest procedure"
an set was return to customer cause he was in hurry
BR.,
Old 01-23-2010, 20:28   #8 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
use old infinity china mircel update 2.63 problem solv 1000000000000% working tested daily
[HELP] iPod Touch 2G Touch Screen not Working! kidgz iPhone 2 / iPhone 3G / iPhone 3GS 1 03-28-2010 12:35
calibrate touch screen not working.. digitized Infinity-Box 3 07-14-2009 09:25
p900 touch screen not working gsm-decode Sony Ericsson 3 07-30-2004 10:36
P900 Touch Pad not working. tanim_1976 Twisterflasher 0 06-17-2004 16:22
SE P800 touch scren not working gibso Sony Ericsson 2 01-13-2004 21:07
Page generated in 0.19053 seconds with 9 queries
