05-28-2008, 13:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | kp130 unlock problem........... Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! cable useing kg800 but not connected with software pls help me argent infinity team |
05-28-2008, 15:33 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | keyboard top 1.........18 1: Gnd 2: phone Rx (RJ45 pin-2) 3: phone Tx (RJ45 pin-3) 5: Gnd 15: Gnd 18: Gnd |
05-28-2008, 17:30 | #4 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | KP130 ok unlock Quote:
Device: LG KP130 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352126022808114 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35212602280811 4_LG KP130_20080528-155207.B1E.bin ........ version: - Check flash Done Check space... current eeprom imei: 352126022808114 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 50 sec Remove/Install battery now ! | |
05-28-2008, 17:39 | #5 (permalink) | |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | Quote:
how to you done it.are you used cable or not used rx tx | |
05-28-2008, 17:56 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is information about cable: http:///vbb/showpo...52&postcount=3 |
05-28-2008, 20:45 | #12 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | ************************KE500,KP130,KP210,KP215,KP 230,KP 235 pinout ******************** keybord up 18.............1 17 - RX (data to phone) 16 - TX (data from phone) 1,4,14,18 - GND |
05-28-2008, 21:07 | #14 (permalink) | |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
with kg800 cable you can change imei and reset to default but for unlock and flash you need ke500 cable i think you got it if you need any more assistance come on msn i will help you how to do it [email protected] | |
05-29-2008, 05:17 | #15 (permalink) | |
thanks sir share for me | |
LG KP130 Hangs Problem Solved Successfully | zeerik | Infinity-Box | 3 | 06-04-2009 17:18 |
KP130 unlocking problem | DYLAN DOG | Rocker Dongle (By Legija) | 5 | 04-10-2009 10:46 |
LG KP130 Unlock with Vygis, Problem Error: Phone not respond | powerplay83 | VygisToolbox | 2 | 08-22-2008 21:52 |
new kp130 unlock problem | a4uuu | VygisToolbox | 2 | 05-20-2008 01:11 |
kp130 unlock problem .help argent | unlock & flash | FuriousGold | 1 | 04-13-2008 14:36 |
