05-05-2009, 12:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Midle of the Earth
Member: 575851 Status: Offline Thanks Meter: 544 | Kp135 succes full unlock and here the pin-out KE500 cable tested 1.........18 pin:1-4-gnd short the pin rj45-pin7 pin:16-TX-rj45-pin2 pin:17-RX-rj45-pin3 pin:14-18-gnd short the pin again rj45-pin8 COM18 [VCP0] selected module v1.38 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 353955020366322 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955020366322_LG-KP135_20090506-074229.B1E.bin .... version: -IDoHGKP135ATV10a Check flash Done Check space ... current eeprom imei: 353955020366322 ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 86 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to ayhen42 For This Useful Post: |
05-05-2009, 21:13 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
here is pin out for K-Touch A-5118 | Jocell_2 | Infinity-Box | 0 | 01-30-2009 13:10 |
the Right way to find the pin out | GalaxyMan | SpiderMan | 3 | 03-27-2008 21:11 |
i need pin out t192 cable | KhOliO | Motorola Old Legacy (EMMI) | 2 | 10-20-2003 06:21 |
unlock GD92 pin out for cable | flechazo | Panasonic | 0 | 09-27-2003 02:25 |
