KP320 flashing error WHAT IS REASON infinity team KP320 flashing error WHAT IS REASON infinity team? i try to all speed 115200.and all boud .but same problem :confused: KP320-00-V10f-CIS-XX-JUL-01-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Y_En_Ru_Kz.B4M COM5 [VCP0] selected module v2.68 Device: LG-KP320 Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Y.BIN ver. sw 2: 7S7610RU00-001-R1Y, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok end mark #4 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:200B:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0209 loader: 3.748.0 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... reading bootloader structure area... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed warning: can't detect nand chip parameters, default values assigned Identification Done Write ... error: unexpected answer: error: incorrect write core parameters error: can't write nand core Write Fail Finished, time used: 92 sec Remove/Install battery now ! sajid..... |
there is prob in ur flash files man download in ths orig firmswere |
@sajidashraf as we can see it may be some problems with some KP320 types, we are checking it carefully now, need some time. |
Hello, Try to make this: 1. download test software: http://www.infinity-box.com/download...9_for_test.rar 2. select model "6228-6230 NAND" 3. flash your phone with KP320 flash file waiting for your results |
same problem with latest version of chinese mircle 2.95 pls rply |
Please, post here operation log so we will be able to check details. |
rehot oar reball your flash chip.. mostly these CPU encounter such errors:) |
lg kp320 restart problem solved tested |
