09-05-2009, 11:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | KP320 Formating Problem module v2.85 Device: LG-KP320 Checking data, wait... Action: NAND reset read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 chip: 0031:200C:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 09 loader: 3.0840.00.00 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done emi configuration... ram size: 02000000 emi configuration done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 115200 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00080000 bytes)... detecting bootloader structure... source data: page only rom info protocol ver: 04 ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1A.BIN ver. sw 2: 7S7610SA00-002-R1A, 00000000 ffs offset/size: 02000000/06000000 id-page1 Ok offset #0 detected size #0 detected parameter #0 detected mark #0 detected offset #1 detected size #1 detected parameter #1 detected mark #1 detected offset #2 detected size #2 detected parameter #2 detected mark #2 detected offset #3 detected size #3 detected parameter #3 detected mark #3 detected offset #4 detected size #4 detected parameter #4 detected mark #4 detected offset #5 detected size #5 detected parameter #5 detected mark #5 detected offset #6 detected size #6 detected parameter #6 detected mark #6 detected offset #7 detected size #7 detected parameter #7 detected mark #7 detected offset #8 detected size #8 detected parameter #8 detected mark #8 detected offset #9 detected size #9 detected parameter #9 detected mark #9 detected offset #10 detected size #10 detected parameter #10 detected mark #10 detected offset #11 detected size #11 detected parameter #11 detected mark #11 detected offset #12 detected size #12 detected parameter #12 detected mark #12 detected offset #13 detected size #13 detected parameter #13 detected mark #13 detected offset #14 detected size #14 detected parameter #14 detected mark #14 detected offset #15 detected size #15 detected parameter #15 detected mark #15 detected After that I found "Range Check error.". ZubairArain |
09-30-2009, 20:09 | #3 (permalink) |
Freak Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 43
Member: 120908 Status: Offline Thanks Meter: 38 | Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read NAND flash read mode: 01 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6229:8A02:8A02]... CPU: MT6229 high speed boot On chip: 0031:0008:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 09 loader: 3.0840.00.00 NAND id: 98F19095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 external ram: 00000000 finalize connection... done emi configuration... ram size: 00000000 emi configuration done ram test... pass 1... error: unexpected answer: warning: ram test failed NOR: 0000:000000000000 [00000000] NAND: 0098:00F100900095 [08400000] NOR chip is not installed Initialize Done Set baud ... 921600 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 35 sec Remove/Install battery now ! this my problem |
09-30-2009, 22:03 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: El M'Hayssar Age: 48
Member: 116657 Status: Offline Thanks Meter: 56 | Quote:
The Following User Says Thank You to BENCHENA For This Useful Post: |
Lg kp320 camera problem | kay_sera.sera | LG | 0 | 03-10-2010 17:12 |
lg kp320 format done | tanha | LG | 2 | 05-03-2009 16:59 |
KP320 Bluetooth Problem, Service Center is changing PCB. Please suggest is PCB NEW? | PkM37 | LG Hardware Repair | 0 | 12-09-2008 15:10 |
MMC formatting problem | jkg | WD2 & APE (Symbian Phones) | 31 | 01-30-2005 02:08 |
memory format-problem | Witek | x1x to x45/x50 | 0 | 09-27-2002 21:04 |
