Lava A3 mini Frp done By CM2 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 186 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741070FA432731C7094 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A40F0794701473 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xA9AF9D77445A3B658B83B177556AC241 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : LAVA ProdName : A3_mini ProdModel : A3_mini Device : A3_mini AndroidVer: 7.0 MTKxCPU : MT6737T MTKxPRJ : alps-mp-n0.mp1-V1.0.2_lava6737t.65.g.n_P4 Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 186 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741070FA432731C7094 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A40F0794701473 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xA9AF9D77445A3B658B83B177556AC241 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! BR, Liton_Bkash |
Good information For security Boot Device.... |
i have trying... but allways result faild... and i succed with this methoud >> https://goo.gl/Mq3hRr |
A3 mini frp done Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM10 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:JHAG4a >>> Downloading Boot2 To Mobile Phone... >>> Initializationing Mobile Hardware Parameter...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003AB400000 -> 15028M Flash ID: 0x90014A4841473461 Flash Name: Hynix_Unknow Flash symbol: JHAG4a >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM31 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM31 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0006A00000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
post Correct Section plz... others was team delete your post...... |
