Old 09-25-2017, 14:28   #1 (permalink)
Member: 85467
Thanks Meter: 104
Blackview A7 frp ?
hy
can do frp on Blackview A7?
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:04
Reconnect Power/Cable!
thx
The Following User Says Thank You to gilica_gsm For This Useful Post:
Old 09-25-2017, 15:21   #2 (permalink)
Member: 696491
Thanks Meter: 164
i THINK YOU HAVEN'T READ THIS MAGIC TRICK POST, IF YOU DID SO THIS POST SHOULD BE IN SUCCESS REPORTS !!
SPENT FEW MINUTES IN READING OR WATCHING
http://forum.gsmhosting.com/vbb/f296...-done-2267636/
OR
https://www.youtube.com/watch?v=Kp5ZOs4-cq4
The Following User Says Thank You to netvision123 For This Useful Post:
Old 09-25-2017, 16:33   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Actually should be enough both side keys pressing during comnect cable.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-25-2017, 17:46   #4 (permalink)
Member: 85467
Thanks Meter: 104
thx for reply but no work
press both vol key:
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847346132A52150A8464495
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
new bin file:
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Boot Error!
Operation Failed
Old 09-25-2017, 17:56   #5 (permalink)
JayDi's Avatar
Member: 462970
Log says another. Sw can't find correct dram config in jnternal db. Will try find it today/tomorrow.
Old 09-28-2017, 08:53   #6 (permalink)
Member: 85467
Thanks Meter: 104
as MTK_AllInOne_DA_SP used DA_SWSWC from SP and done frp
phone work fine
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-07-19.22:57
Running DA ver.4.2 on BBID : 0x9C
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4G8
[eMMC] : FLASH_CID : 90014A483847346132A52150A8464495
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x20D426B7CE0325AE9D9752C1A596FAEE
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Blackview
ProdName : A7
ProdModel : A7
Device : A7
AndroidVer: 7.0
MTKxCPU : MT6580
MTKxPRJ : A7-Blackview-V0.8-20170802
SECURITY :
IMEI_SW [1] : 352449090439582
IMEI_SW [2] : 352449090439590
BTMAC Addr : DA3746658090
WiFi MAC : 000000000000
Done!
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
rgds
Old 09-29-2017, 10:38   #7 (permalink)
Member: 2739449
Thanks Meter: 185
It helped. Thank you.
Old 11-03-2017, 11:58   #8 (permalink)
Member: 1350761
Thanks Meter: 24
How change DA in CM2?
Old 11-05-2017, 11:41   #9 (permalink)
Member: 696491
Thanks Meter: 164
Originally Posted by cinik79 View Post
how change da in cm2?
read and follow second (2nd) post again, you will understand every thing
br: Habib
The Following 2 Users Say Thank You to netvision123 For This Useful Post:
Old 12-13-2017, 16:12   #10 (permalink)
Member: 392459
Thanks Meter: 2
what are you doing exactly ? from where you found the file boot ?
phone work fine
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : Blackview
ProdName : A7
ProdModel : A7
Device : A7
AndroidVer: 7.0
MTKxCPU : MT6580
SECURITY :
Done!
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
rgds
Old 12-14-2017, 10:54   #11 (permalink)
dr.danielman's Avatar
Member: 356508
Thanks Meter: 132
boot file ?
i need that boot file too
THX
Old 12-19-2017, 21:35   #12 (permalink)
DomnulV's Avatar
Member: 1447
Thanks Meter: 97
if receive error, just erase manual from spflashtool, frp partition, with da_swsec.bin agent.
artition_name: frp
file_name: NONE
is_download: false
type: NORMAL_ROM
linear_start_addr: 0x4fa0000
physical_start_addr: 0x4fa0000
partition_size: 0x100000
tested.
TNX,
Cris
The Following User Says Thank You to DomnulV For This Useful Post:
Old 03-10-2018, 18:12   #13 (permalink)
Member: 1917054
Thanks Meter: 268
https://www.youtube.com/watch?v=LtuRzuqo78I
Old 12-26-2019, 16:09   #14 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Thanks Meter: 693
Card found : S/N : xxxxxxxxx , v0136
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DA Select done, will use SecMode DA
eMMC Flash : 45010044463430313601921F04C584CF
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , 6104F
[eMMC] : FLASH_CID : 45010044463430313601921F04C584CF
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0x6921A19AED346DA3E6F9B76F6A6EB9A7
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Brand : Blackview
ProdName : A10
ProdModel : A10
Device : A10
AndroidVer: 7.0
MTKxCPU : MT6580
MTKxPRJ : alps-mp-n0.mp2-V1_pri6580.weg.n_P25
SECURITY :
IMEI_SW [1] : 354745090018864
IMEI_SW [2] : 354745090018872
BTMAC Addr : 6E30466580BE
Done!
Elapsed: 00:00:27
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:15
The Following User Says Thank You to gulshan-iqbal For This Useful Post:
Page generated in 0.36730 seconds with 8 queries
