Lc m501 cpu: Mt346c problem COM9 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 16 sec Remove/Install battery now ! software version: 1.20 cable type: 1x12 (L12C) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM9... adapter found, version: 4000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT346C result: Rx:3 Tx:7 time required: 15 sec Trying to Power-On... Power On ! Power On ! how to work with this cpu |
hello! select 6253 NOR in China Miracle setting page |
same story COM9 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! |
same here pz updte box |
sorry pz updte in support site |
You must tell me now - what is the problem with your phone. Is it dead phone ? |
You must post here an explanation of problem instead of write "same". Now we are waiting for your explanation ! You must Make explanation urgently !!! |
You must post here an explanation before you ask for update ! |
yes the phone is dead and i want to fomart but i get this error |
Hello connect rx tx with board try to format with direct cable without pinfinder & post here result..... |
hello! if you read log- you can see that flash chip can not be detected. which means that phone need hardware reapir. resoldering or flash chip change |
