04-11-2017, 12:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2119608 Status: Offline Thanks Meter: 41 | Le X528 qualcom not reading firmware Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01FE0EB7 ID_BLOCK_I : 009900E1 ID_BLOCK_E : 00000001 ID_BLOCK_L : 7C214EBEC5B60F29C97667028AD560CB ID_BLOCK_L : 33014F79493595A5E7580095A59FEB27 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LeEco ProdName : Le2_CM Device : le_s2_cm AndroidVer: 6.0.1 Manufact. : LeMobile QLMxCPU : MSM8952 QLMxPRJ : IJXCNCM5801607282S Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01FE0EB7 ID_BLOCK_I : 009900E1 ID_BLOCK_E : 00000001 ID_BLOCK_L : 7C214EBEC5B60F29C97667028AD560CB ID_BLOCK_L : 33014F79493595A5E7580095A59FEB27 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LeEco ProdName : Le2_CM Device : le_s2_cm AndroidVer: 6.0.1 Manufact. : LeMobile QLMxCPU : MSM8952 QLMxPRJ : IJXCNCM5801607282S DevInfo : MSM8952__LeMobile__LeEco__ANDR_v6.0.1__le_s2_cm__L e2_CM__IJXCNCM5801607282S ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Send report to mail : [email protected] with title "QFW" ! Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 01FE0EB7 ID_BLOCK_I : 009900E1 ID_BLOCK_E : 00000001 ID_BLOCK_L : 7C214EBEC5B60F29C97667028AD560CB ID_BLOCK_L : 33014F79493595A5E7580095A59FEB27 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : LeEco ProdName : Le2_CM Device : le_s2_cm AndroidVer: 6.0.1 Manufact. : LeMobile QLMxCPU : MSM8952 QLMxPRJ : IJXCNCM5801607282S DevInfo : MSM8952__LeMobile__LeEco__ANDR_v6.0.1__le_s2_cm__L e2_CM__IJXCNCM5801607282S ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Send report to mail : [email protected] with title "QFW" ! Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
04-11-2017, 12:39 | #2 (permalink) |
Member: 2119608 Status: Offline Thanks Meter: 41 | i have sent the report.log to [email protected] |
