lenouvou 2020 vibe C enable diag mode hello pleaz haw enable diag mode in to lenouvo vibe C 2020 |
two methods, one use voulme down and connect cable, two root and enable diag by adb |
i try wthe volum down no work pleaz teel me haw to root |
volume up,, sorry my mistake |
https://www.youtube.com/watch?v=Hg0unaQQ5NE |
Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Write Security [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00009601 MODHW : 0000100C BUILD : MPSS.JO.1.0.c5-00051-M8909EAAAANVZM-1.46590.1.66140.1 RTIME : Feb 14 201710:08:42 BTIME : Aug 08 201607:00:00 DEVST : 8909.gen Update IMEI[1] : 843256921126xxx Record update Ok! Update IMEI[2] : 843256921126xxx Record update Ok! Write done! Reboot device, if it not restart! Hint : QCN write and Factory Reset is required to finish process completely! Done! Elapsed: 00:00:03 Reconnect Power/Cable! |
