11-15-2015, 11:49 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | lenovo A238t died after flashing, please how to revive? Card found: S/N : B25B7C49 , v0129 Chinese Miracle II [SPD module] v 1.05 Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC8830 Generic Loader NANV v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Generic Loader NAND v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Boot Files missing! Select SLDR or PAC file! Boot failed! Reconnect Power/Cable! Loading : A238t S231 140803.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC88xx_NAND PacVersion : A238t_S231_多国语言20140803 FastCheck : 0x1F4DE157 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem2.bin File : prodnv_b256k_p4k.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : modem2.bin File : boot_logo.bmp File : boot.img File : system_b256k_p4k.img File : cache_b256k_p4k.img File : recovery.img File : userdata_b256k_p4k.img File : u-boot.bin File : prodnv_b128k_p2k.img File : system_b128k_p2k.img File : cache_b128k_p2k.img File : userdata_b128k_p2k.img File : SC88xx_NAND.xml Load Ok! Operation : Flash [ v1.05 ] ======= Flash Files set for flashing : [ MCU ] : A238t S231 140803.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC88xx_NAND PacVersion : A238t_S231_多国语言20140803 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem2.bin File : prodnv_b256k_p4k.img File : u-boot-spl-16k.bin File : modem.bin File : DSP.bin File : modem2.bin File : boot_logo.bmp File : boot.img File : system_b256k_p4k.img File : cache_b256k_p4k.img File : recovery.img File : userdata_b256k_p4k.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x16 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv_b256k_p4k.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_TD Current File : modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_TD Current File : DSP.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : modem2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : boot_logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : tdruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : SYSTEM Current File : system_b256k_p4k.img Flashing now ... [FlashProc] : Error with code 0x0003 Elapsed: 00:01:07 Reconnect Power/Cable! |
11-16-2015, 12:53 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Missing apps, die during factory reset - does it tells you something? Or, better - make new thread, like you done before : "CM2/BEST killing phones! Don't use it!" |
