05-04-2009, 12:02 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | b259 samsung cdma sucessfully unlocked module v1.03 Device: Samsung-SCH-B259 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 13 sec Remove/Install battery now ! thxs.infinity team...................................... wbr. rajesh ch. |
The Following 2 Users Say Thank You to rajesh_ch For This Useful Post: |
05-05-2009, 21:19 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
09-03-2015, 07:26 | #3 (permalink) |
Major Poster Join Date: Feb 2012 Location: jalgaon
Member: 1726688 Status: Offline Thanks Meter: 9 | b259 samsung cdma pls solution this problem COM63 [sscdmdm0] selected module v2.05 Device: Samsung-SCH-B239, B259, B279, F302 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" If problem still exist make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 47*869#123580 4. go to "Port Map", HKF 5. select "UART2" error: operation failed Finished, time used: 25 sec |
09-03-2015, 08:01 | #5 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Open Back Sticker You Will Be See Some Pinout Just Make Jumper And Unlock By Normal Any Rx Tx Cable Here Is Cable Pinout | |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
09-03-2015, 17:21 | #6 (permalink) |
Member: 1726688 Status: Offline Thanks Meter: 9 | Thank you pradip kus Rj-45 cable kat kar Rx-Tx Vcc Gnd Connect kiya 10 Second me hogaya. COM41 [VCP0] selected Samsung B259 succsess unlock- Green mobile raver 9881365569 module v2.05 Device: Samsung-SCH-B239, B259, B279, F302 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 37 sec |
The Following User Says Thank You to munajir85 For This Useful Post: |
B259 samsung cdma unlock successfully!! | kmaxmax | Infinity-Box | 3 | 05-05-2009 15:45 |
Samsung A707SCII Sucessfully Unlocked | Ultimate Server | NSPRO | 0 | 02-25-2009 15:43 |
Samsung A127 Sucessfully unlocked | .::AZEEM::. | UST Pro II | 2 | 01-22-2009 12:56 |
Samsung x530 sucessfully unlock | zhettie_foxie | Samsung Flashers, Software, Firmware. | 1 | 07-16-2007 14:03 |
