11-07-2017, 09:22 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Lenovo a6000 error while flashing 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 08B3325C ID_BLOCK_I : 007050E1 ID_BLOCK_L : 699BF10DA836232E194E868F4813A3AB ID_BLOCK_L : 6EE5AB02F79EC04578B718D1D3D2CC0F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : Lenovo ProdName : Kraft-A6000 ProdModel : Lenovo A6000 Device : Kraft-A6000 AndroidVer: 5.0.2 Manufact. : LENOVO SysPatch : LRX22G DevComTime: 10/30/2015 3:43:01 AM QLMxCPU : MSM8916 USERData : NORMAL GCSec : NORMAL Done! Elapsed: 00:00:17 Reconnect Power/Cable! Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Lenovo Device Manufact.: LENOVO Device Model : Kraft-A6000 Device CPU : MSM8916 Device IntName : Kraft-A6000 Device Version : 5.0.2 CU_SWVer : LENOVO Device Compile : 10/30/2015 3:43:01 AM Device ExtInfo : Lenovo A6000 Load Ok! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 08B3325C ID_BLOCK_I : 007050E1 ID_BLOCK_L : 699BF10DA836232E194E868F4813A3AB ID_BLOCK_L : 6EE5AB02F79EC04578B718D1D3D2CC0F Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 32 Flashing now Flashing : gpt_main0.bin ProgStart : start 0, num 34 ProgFinish : Read back verify failed at sector -1933717111,num sectors 0 Flash Error , Wrong ACK message! Bad File or eMMC fault? Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
11-08-2017, 00:20 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | Code: Flash Error , Wrong ACK message! Bad File or eMMC fault? If init ok - right click and do eMMC read/write test. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
11-11-2017, 21:17 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,784 | high probability of eMMC malfunction. if you do hardware repairs - open phone, and reflow eMMC IC, then retry process. b.r. Alex
