01-29-2016, 10:14 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2004 Location: Bangladesh Age: 44
Member: 54228 Status: Offline Thanks Meter: 76 | lenovo A606 flash help Chinese Miracle II [MTK module] v 1.40 User selected Preloader file : preloader_lcsh82_slw_cu_kk.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 1501004B3758564D42 , Name : K7XVMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A483847326404 , Name : H8G2d , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:27 Reconnect Power/Cable! User selected Preloader file : preloader_lcsh82_slw_cu_kk.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 1501004B3758564D42 , Name : K7XVMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A483847326404 , Name : H8G2d , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420184C1CE15913F DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Flash Erase [ v1.40 ] User accepted Flash Erase operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420184C1CE15913F DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6582 , Project : lcsh82_slw_cu_kk , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420184C1CE15913F DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! User selected Preloader file : preloader_lcsh82_slw_cu_kk.bin Bad file selected! Preloader looks like damaged! User selected Preloader file : preloader_lcsh82_slw_cu_kk.bin Bad file selected! Preloader looks like damaged! User selected Preloader file : preloader_aux.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 1501004B3758564D42 , Name : K7XVMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 1501004B355530304D , Name : K5U00M , Vendor : 15 , [SAMSUNG] FlashID [2] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420184C1CE15913F DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
01-29-2016, 12:08 | #3 (permalink) |
Member: 54228 Status: Offline Thanks Meter: 76 | bro already try 3 type version and try preloader repair but no luck here log User selected Preloader file : preloader_lcsh82_slw_cu_kk.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 1501004B3758564D42 , Name : K7XVMB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A483847326404 , Name : H8G2d , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D420184C1CE15913F DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! |
