08-13-2016, 08:49 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Imei repair failed it1501 Phone found! [ 64 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Write new security data : IMEI1 : 358265012340953 IMEI2 : 358265017798650 Error while check security Block #1! Seems as damaged! Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [8/12/2016 / 6:11:06 PM] |
08-13-2016, 09:04 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Flash FW with NVM update or read NVM from alive phone and write to that with DeepFix enabled. |
