10-25-2008, 09:14 | #1 (permalink) |
Insane Poster Join Date: Aug 2007 Age: 43
Member: 575824 Status: Offline Thanks Meter: 4 | Lenovo e307 reset I TRY TO RESET LENOVO E307 GET FOLLOWING ERROR,SEEK ANY HELP. COM3 [VCP1] selected Device: Lenovo E307 Checking data, wait... Action: reset Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... error: unexpected rx block size: 001FD9/002000 error: unexpected rx block size: 001F52/002000 error: unexpected rx block size: 001FD5/002000 error: unexpected rx block size: 001FC5/002000 error: unexpected rx block size: 001F28/002000 error: unexpected rx block size: 001F4F/002000 error: unexpected rx block size: 001E05/002000 error: unexpected rx block size: 00131A/002000 file saved: G:\backup_eeprom_ffs_20081025-130627.9BF.bin Check Parameters Done Check Space... error: connection lost#1 error: flash chip can't be detected: error: flash chip can't be detected: Check Space Fail Finished, time used: 53 sec Remove/Install battery now ! |
10-27-2008, 12:09 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone can not make 112/emergency call well (or power-off during this call) it\'s a hardware problem, probably you neede to replace PA. Connection problem: it may be problems due to not good cable. If you still want to flash phone try to use other cable or more short wires from box to phone. |
chineese Lenovo E307. Please help me | Eddy25 | Lenovo | 2 | 09-06-2015 06:01 |
reset usercode m8910 ok with z3x | sirnavid2010 | Z3X-Team Products | 0 | 03-29-2010 12:05 |
Lenovo E307 Can't flash | thushdt | Infinity-Box | 1 | 03-27-2009 10:56 |
How to reset user lock Lenovo V850 ??? | thuanrau | Infinity-Box | 1 | 04-09-2007 05:50 |
09 Dec 2006: Fly M100, Lenovo E307 models supported | InfinitySupport | Infinity-Box | 12 | 01-06-2007 17:54 |
