Lenovo k8 note after reset frp dl image fail error... Lenovo k8 note after reset frp dl image fail error... FRP Reset logs Quote:
i tried Fix Dl function ..... Quote:
But still the phone is stuck in DL Image fail error. The phone was working fine before resetting Frp. Now im stuck with this problem .. There is no firmware available over the net. Can anyone please help me regarding this issue. |
Hi Quote:
read file with cm2 in this condition after read use sptool to solve dl error select file tick on only cache with dl checksum ;) |
fix dl by cm2 in seconds |
thnx for your attention.... i will try and post result soon... |
@mobite i have tried your method but no luck phone is still showing Quote:
dm me for the solution |
It is not that much difficult. Just read all info by cm2.. get project id and download corresponding firmware. Flash it and solved. All you need is correct project id to download correct firmware. |
Use SP tool instead to CM2 in case...... |
