lenovo xt1902-3 i cant flash plaz help customer bring phone for unlock FRP FRP reset protection is done using InfinityBox CM2MTK but after reset frp phone DL image error.i try to fix DL mode but Interpage come fridge thin i try to flash phone but error here is logo Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 4604F [eMMC] : FLASH_CID : 45010044463430363401BED3034D84B1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0x20DEE098ED5D0F0FA7914264B6F05D67 INT RAM : 0x00000000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! ScatCFG : BaseBand : MT6797 , Project : manning , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility BL : Undefined structure, determined as forced M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000001B80000 Erase : 0x0000000002388000-0x0000000004000000 Erase : 0x0000000007800000-0x0000000000800000 Erase : 0x0000000008500000-0x0000000002600000 Erase : 0x000000000B000000-0x000000027E000000 Flash Erase Done, time used : 00:00:01 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
Hello, Use Latest MTK version I.E 2.04 http://forum.gsmhosting.com/vbb/f296...vated-2556648/ |
https://i.postimg.cc/bYScvZLK/screenshot.png my dongle is upto date |
Hello, It looks like your dongle support period is expired. How to check - https://forum.infinity-box.com/viewtopic.php?f=3&t=1097 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ |
thank you bro my problem solve using SP_Flash_Tool_v5.1816 |
