01-05-2009, 21:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 522123 Status: Offline Thanks Meter: 44 | lg 2050 dead HERE IS THE LOGS BELOW :: COM1 [VCP0] selected module v1.36 Device: LG-B2050 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 flash: ST M30L0R7000B0, M36L0R7040B0 B 16Mb id: 00005272 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 356558005573164 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356558005573164_LG-B2050_20090106-135057.B1E.bin ........................ Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 Write: Alchemy data flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 Write Done Finished, time used: 394 sec Remove/Install battery now ! |
LG 2050 Dead After Charging | Ankit Verma | LG | 0 | 04-17-2008 12:24 |
any application to download the ringtones and wallpapers in LG 2050 | parthiv_sk | LG | 4 | 09-28-2006 20:51 |
lg 2050 charging problem | pratikk | LG | 0 | 07-29-2006 13:14 |
LG 2050 needed françai flash | nasro_nd | LG | 1 | 01-17-2006 12:40 |
Lg 2050 | Fast Unlocker | Blazer | 2 | 09-26-2005 11:19 |
