10-16-2014, 13:14 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | hi sir my box is not connect set with rx tx its say cable problem but i change 3 cables its show same error here is set info its connect ok with volcano CPU ID: 880A 7002(CT8853B) Flash ID : 002CCB17 Flash Type: SF_N25W64 Flash Len :0x800000(8M) |
10-16-2014, 13:23 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Looks like you do something wrong. Check - correct port selected in software, or use box as com port. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-18-2014, 07:51 | #5 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | problem is solve here is info Com Port Opened Press and hold POWER button! Waiting phone Init Ok 1st boot Ok ==== CPU CPU_ID : 880A , rev : 7002 CPU_CN : CoolSand CT , RDA8853B ==== FLASH FL_VEN : CB2C , rev : 1700 FL_CNM : Micron , N25W64 FL_CAP : 00800000 ==== Booting Sending RamRun Loader... Set : 880A , 00800000 Use : 880A_00800000.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Loader run Boot Ok Release Power button! Boot Done! Elapsed: 00:00:05 Done Reconnect Power/Cable! |
The Following User Says Thank You to saqi160 For This Useful Post: |
