Old 03-10-2009, 11:01   #1 (permalink)
Member: 188484
Thanks Meter: 117
How to read flash MT6235?
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6235, E04
Hardware version: RATECH35_08A_HW
Software version: X8_XZY_MLB_1_6T07S01
Software date: 2000.00.00
Barcode: MT012345678901234567
imei: 357000008011931
imei: 357000008011434
Finished, time used: 5 sec
Power off phone now !
I need for editing language.
The Following User Says Thank You to alunecosu_hd For This Useful Post:
Old 03-10-2009, 15:45   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hi,
Did you tried to read full flash like "Autodetect 6205-6227 NOR" model ?
What is the results ?
Old 03-10-2009, 21:32   #3 (permalink)
Member: 188484
Thanks Meter: 117
I try but soft error read cip id ...I try 115200 speed but identic
Old 03-10-2009, 22:32   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, post here operation log text with flash read try.
Old 03-12-2009, 09:38   #5 (permalink)
Member: 188484
Thanks Meter: 117
COM4 [VCP0] selected
module v2.78
Device: Autodetect 6205-6227 NOR
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
error: can't detect CPU id
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 23 sec
Remove/Install battery now !
baudrate 115200 and more....
Old 03-12-2009, 09:46   #6 (permalink)
Member: 188484
Thanks Meter: 117
This is CESIM V800 mtk 6235 ...
Old 03-12-2009, 09:55   #7 (permalink)
Member: 445967
Sonork: 100:1652029
Thanks Meter: 37
I u select china miracle unkwon chip set may be its ok try to best ... And press thanks
Old 03-12-2009, 10:17   #8 (permalink)
Member: 188484
Thanks Meter: 117
I try but not work.and with pind finder not detect pinout...
Old 03-13-2009, 00:50   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we will check what could be wrong
Old 04-30-2009, 22:11   #10 (permalink)
Member: 20554
Hi all,
any news about v800 mt6235 pinout?
thanks for your aswer
Old 05-01-2009, 07:02   #11 (permalink)
Member: 188484
Thanks Meter: 117
KSAT pinout exist see my post ...
Old 05-01-2009, 16:40   #12 (permalink)
Member: 20554
alunecosu_hd thanx, but
I mean pinout for datacable(with pl2303) to read/write flash without phone disassembling
is it possible?
Old 05-30-2009, 12:50   #13 (permalink)
nui
Member: 237095
I same can not read flash
Old 05-31-2009, 23:13   #14 (permalink)
Member: 148515
hello!
please provide logs, i will help by advice
Old 06-01-2009, 07:32   #15 (permalink)
Member: 20554
hi all
here is pinout for datacable (pl2303) you can modify samsung d500 cable
count pins when you look on connector from left to right
8 - Тx
9 - Rx
17+18 - GND
you can use
FlashTool_v3.0840.00
to read\write flash
set operations method NFB
there are 2 firmware vesions i know last X8_XZY_MLB_1_7T08S0309 2009/03/09
master full can be found here http://rapidshare.com/files/23600470..._Pavel.7z.html
to update firmware you need to load scat_6235_Pavel.txt (Scatter-loading )
after flash make reset for factory settings password 1122
How to read flash from Withus WCE-100? dennt Various CDMA/TDMA Cell Phones 13 05-07-2007 17:33
How to read Flash and send them to support??? byteforce Cruiser Suite 2 06-03-2006 13:25
how to read flash to a-840 ? smso Motorola P2k 0 05-23-2006 10:10
how to read flash to d-500 smso SWIFT Platform 5 06-22-2005 20:31
How to read flash from S300 to file Birisx Trident/AGERE Platform 0 07-22-2003 09:15
Page generated in 0.25677 seconds with 10 queries
