Old 09-12-2007, 07:41   #1 (permalink)
Member: 249213
Thanks Meter: 7
LG C1150 auto restart help!
My LG C1150 after flash code, alchemy data & Eeprom, the C1150 now auto restart, please help!
Old 09-12-2007, 07:47   #2 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 639
use infinty mate flash the eeprom again if sucess flash again using vygis flash the firmware and alchemy tested by me
br
Old 09-12-2007, 08:41   #3 (permalink)
Member: 249213
Thanks Meter: 7
i only have infinity box, is there any other way can use infinity box to fix this problem? please help & advice.
Old 09-12-2007, 09:56   #4 (permalink)
Member: 130995
Thanks Meter: 35,155
@kennyt1
use latest LgA module from support area, flash phone again, try to use repair eeprom.
Old 09-22-2007, 04:29   #5 (permalink)
Member: 249213
Thanks Meter: 7
Exclamation
Hi Infinity support team.
Please see my flashing status shown as attatchment:
please advice & help how to solve restart problem, somemore infinity support download only have euro flash files, don't have APAC for my country. please help % advice!
File Type: txt reset-setting.txt (852 Bytes, 21 views)
File Type: txt SP-unlock.txt (772 Bytes, 18 views)
Old 09-22-2007, 11:39   #6 (permalink)
Member: 148515
Thanks Meter: 19,258
hello kennyt1!
have you tried write repair eeprom?
Old 09-22-2007, 12:58   #7 (permalink)
Member: 249213
Thanks Meter: 7
Red face
This is write Eeprom status show as below:
COM22 [VCP0] selected
Device: LG C1150
Checking data, wait...
advanced flash detection active
Action: flash write
Skip: Firmware (code)
Skip: File system
Skip: Alchemy data
Write: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 98008400000032:FEEA0000000000
flash: Toshiba B 8Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 357751003743132
file saved: backup_eeprom_357751003743132_LG C1150_20070922-195202.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write: Eeprom
Write Done
Finished, time used: 38 sec
Remove/Install battery now !
After write Eeprom the phone still auto restart after turn on phone 15-20 sec.
Is there any APAC flash file for LG C1150?
Please advice & help.
Old 09-26-2007, 05:05   #8 (permalink)
Member: 249213
Thanks Meter: 7
Red face
Dear, Infinity support team, is there any step i miss out? or there is no solution for LG C1150 auto restart problem? other than this flash files at support download "C1150P16FL_V10b-33_208-10_DEC-13-2005_code.B1M" & "C1150P16FL_V10b-33_208-10_DEC-13-2005_alchemy.B1P" is there any (APAC) support for my country? please help!
Old 09-26-2007, 05:18   #9 (permalink)
.::AssAnovic.::'s Avatar
Member: 162611
Thanks Meter: 316
Thank you infinityteam...........
Old 09-26-2007, 18:03   #10 (permalink)
Member: 148515
hello kennyt1!
i dont see other way to reapir it, only by flashing 3 parts at once:
main+alchemy+eeprom. this must work
regarding APAC languages: we can add needed languages/files after you send us full backup readed from such phone.
F480 auto restart. Help me .. :( cool_boy198x QUALCOMM Models (3G) 1 01-24-2009 13:52
n95 jammed then auto restart ,,,,help me vijaya7668 Nokia Hardware & Hardware Repair 4 05-05-2008 04:19
V3i auto restart help needed urgent .::AD Com::. Smart-Clip 13 08-03-2007 19:21
Sharp 902 auto restart Help!! plzzz Jeyper Sharp 6 09-30-2006 15:15
Page generated in 0.18134 seconds with 10 queries
