08-16-2008, 07:31 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | LG C2500 successfull format with Infinity. Device: LG C2500 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6217:8A00]... CPU: MT6217 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... detecting firmware version... .................................................. .............. .................................................. .............. .................................................. .............. can't detect firmware version if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting languages... ........................................ language parameters detected detected languages: En Tr Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080816-111645.A3E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:C214A700000000 Finalization Done Finished, time used: 285 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
08-17-2008, 13:45 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Cable Compatible For LG C2500 For ET Box / Infinity Box / Vygis Box / Blue Box | IPMART | ipmart WebShop | 0 | 05-15-2009 11:40 |
i-Pmart BX Series RJ45 Cable For LG C2500 For ET Box / Infinity Box / Vygis Box / Blu | IPMART | ipmart WebShop | 0 | 05-14-2009 16:00 |
LG C2500 Successfull format | Shakeel_pattoki | Infinity-Box | 3 | 09-08-2008 00:47 |
lg c2500 sucsecssfully flash in infinity | .::AZEEM::. | Infinity-Box | 3 | 01-18-2008 09:09 |
Successfull N78s With Infinity | .::KHURRAM::. | Infinity-Box | 3 | 09-18-2007 13:58 |
