05-27-2016, 17:52
#3 (permalink)
Member: 44659
Thanks Meter: 363 | Quote:
Originally Posted by JayDi Hello. Not got a point - does device is fixed? Or you looking for a dump? | Phone wasn't fixed, just reporting cm2mtk readings ...
Previous one -> [eMMC] : FLASH_INF : [HYNIX] , d1G4
This one was stuck at logo, flashtool fails but other tool was able to recover the phone (LGE450gAT-00-V10c-714-YYY-FEB-14-2014) Quote:
Operation : Check / Read Info [ v1.47 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.192.3 on BBID : 0x02
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 110100303034473930506095D47621D7
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 06A219828C8947131F2EFA93B5458540
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok! Info read not done Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:00:17
Reconnect Power/Cable!
| Quote:
Operation : Read NVRAM [ v1.47 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok! Not found required data
Done!
Elapsed: 00:00:18
| Quote:
Operation : Read Flash [ v1.47 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Read Ok , collect info
MTKxCPU : MT6575
Saved to : E:\MT6575.ispff
Done!
Elapsed: 00:54:58
