02-11-2020, 15:22 | #1 (permalink) |
Insane Poster Join Date: Sep 2011 Location: Pakistan
Member: 1659750 Status: Offline Thanks Meter: 22 | unable to repair imei on mtk 6260 please help Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 57 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : C1A70365A20134BB862DCF30E25EC247 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00FC , [GigaDevice] GD25LQ256 [0] : FLASH_DIE : 00C8 0060 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Read Security data ... Verify Security data ... Repair failed with code : 0x02 ! Security aread damaged Operation Failed Elapsed: 00:00:45 |
06-15-2022, 09:36 | #6 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | Card found : S/N : 97A90C62 , v0150 Chinese Miracle II [MTK module] v 1.58 Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 25 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 0C192332B05AACD8D6155E4C0DB6E9A6 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00ED , [GigaDevice] GD25LQ64 [0] : FLASH_DIE : 00C8 0060 0017 0000 [0] : FLASH_LEN : 0x00800000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read Security data ... Verify Security data ... Repair failed with code : 0x02 ! Security aread damaged Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
