01-24-2017, 13:46 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Poland Age: 47
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | Xiaomi Redmi 3s (land) account reset NOT DONE Forced Fix Repair, etc doesn't help. When phone goes online, phone is blocked. Code: Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 0077AC66 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : F8A12200ACBB6D30411BA5E074E61639 ID_BLOCK_L : 41BFB56CA38A9C520D9C35304FBF6B5E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G32 Boot Ok! MIAccount reset passed! Normal reset : > Select "FORCED FIX" or "REPAIR" in FMT settings, press "Format FS / Reset Settings" > PowerOn device and use. IF Device stuck on black screen with cable - use another FMT > Not all devices supported yet! (tested on Hydrogen,Land,Redmi2) Done! Elapsed: 00:00:22 |
01-24-2017, 15:24 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Which version u have in mble try with this file http://bigota.d.miui.com/V7.5.8.0.MA...0b73f8c25c.tgz |
The Following User Says Thank You to princesaddam For This Useful Post: |
01-25-2017, 10:22 | #5 (permalink) | |
Member: 42387 Status: Offline Sonork: 1573735 Thanks Meter: 407 | Quote:
02-27-2017, 11:02 | #8 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,102 | Quote:
if you have bootloader loocked you have no chance freind........ | |
