08-14-2009, 15:06 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Bermuda Triangle
Member: 776382 Status: Offline Thanks Meter: 105 | lg ke970 error: can't run main loader Wanted to apply this other solution i just met by in forum by SHINE flash LG ke970 without restart problem posted earlier: " testerday i had a ke970 restart when power on i serched on this section but i didn't found the solution. now problem sloved so i want to share the solution may be help other members. 1 full charge the battery before flashing phone 2 i choose thoes files - KE970P40-AFR-V10i-000-00_JUL-30-2007_firmware.B1M - KE970P40-AFR-V10i-000-00_JUL-30-2007_file_system.B1S - KE970_repair_eeprom_complete_10.B1E 3 choose reset setting 4 write languages on this flash are 20: (english,français,deutsch,italiano,portugues,espan ol,turkish,dansk,nederlands,suomi,magyar,norsk,pol ski,roman...) here's the log: COM4 [VCP0] selected module v1.60 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: Eeprom Verifying... Done Write Done Finished, time used: 3480 sec Remove/Install battery now ! Anyone help me revive it module v1.69 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 11 sec Remove/Install battery now ! |
The Following User Says Thank You to kfkevin For This Useful Post: |
08-15-2009, 06:48 | #2 (permalink) |
Member: 776382 Status: Offline Thanks Meter: 105 | Infinity team help me revive lg ke970 module v1.69 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 11 sec Remove/Install battery now ! |
02-22-2010, 20:38 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | I think its all about wrong flashing specially if tried with gsmmulti ... it will flash ke970 completely but after flashed ur set wont be powered on anymore which was restarting or stuck with lg logo .. and then u cant flash it with any known device even not again with Gsmmulti !!! here u may check same thing http://forum.gsmhosting.com/vbb/show...ighlight=ke970 but if we flash it with fg , infinity , z3x problem sometime solved but it will never die like this I cant find any solution for this type of problem which is not boot after flashed with gsmmulti ... yet !!! |
03-28-2010, 14:22 | #7 (permalink) |
No Life Poster Join Date: May 2007 Location: MOROCCO
Member: 510826 Status: Offline Thanks Meter: 183 | [QUOTE=YellowBoss;5467466]In some cases it's a result of hardware damage. What is your phone history ?[/QUOTE] it is not hardware problem i have a same problem i flashed it with free soft FlashTool_E2_1128_stable(ke970) |
03-29-2010, 00:28 | #11 (permalink) |
Member: 510826 Status: Offline Thanks Meter: 183 | [QUOTE = YellowBoss; 5636751]Ce n'est pas moi ont un problème de matériel i même problème il brilla avec Free FlashTool_E2_1128_stable mous (KE970)[/ QUOTE] mai il être un logiciel ou de matériel. [/ QUOTE] infinity box never kill the phone ; I flashed it with infinity box 3 times , & the laste time with free soft , so it is the free soft " flash tool " who has damaged the phone . The size of flash KE970 does not exceed 18 Mo , but the size flash that i downloaded it is 128Mo this is not normal ! |
03-29-2010, 14:45 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, All Infinity-Box flash files is packed (f.e. like RAR) and files unpacked on the fly during flash process, it's the reason of small file size. |
04-11-2010, 08:17 | #15 (permalink) | |
Member: 510826 Status: Offline Thanks Meter: 183 | Quote:
COM3 [VCP2] selected module v1.76 Device: LG-KE970 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 6 sec Remove/Install battery now ! | |
Huawei T201:error: can't run main loader: | beneto | Infinity-Box | 12 | 03-03-2010 21:52 |
KE970:can't run main loader ! | jawad8305 | Infinity-Box | 5 | 06-18-2009 09:30 |
Vodafone 227 can't run main loader | Artist | Infinity-Box | 5 | 05-28-2008 13:33 |
LG KE970 error: can't run main loader | green bird | Infinity-Box | 1 | 02-16-2008 21:17 |
