Old 11-07-2008, 04:26   #1 (permalink)
Member: 75838
Thanks Meter: 67
Ke970 error
i have ke970, problem with this error. plz help
Old 11-07-2008, 04:53   #2 (permalink)
sood's Avatar
Member: 812373
Thanks Meter: 47
i think salect speed 921600......... chack and past agin
The Following User Says Thank You to sood For This Useful Post:
Old 11-07-2008, 06:07   #3 (permalink)
Member: 75838
Thanks Meter: 67
i also select 921600 baud rade
The Following User Says Thank You to sunil kumar For This Useful Post:
Old 11-07-2008, 10:11   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Make "backup system area" box un-checked and repeat operation
Old 11-07-2008, 10:12   #5 (permalink)
royal_electronics's Avatar
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow Lg k970 range error
I ALSO FACE THIS PROB. PLZ GIVE SOLUTION
Old 11-07-2008, 10:16   #6 (permalink)
Member: 130995
Hello,
Old 11-07-2008, 11:31   #7 (permalink)
Member: 75838
Thanks Meter: 67
i also uncheck backup system area but still no solution
Old 11-07-2008, 11:41   #8 (permalink)
Member: 130995
Hello,
We will check software to see what may be wrong.
Old 11-07-2008, 15:15   #9 (permalink)
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow K970
SAME PROB. I FACE IT.I AGREE WITH U
Old 11-07-2008, 17:12   #10 (permalink)
Member: 113924
Thanks Meter: 29
Use old software PANA01. V1.50
Old 11-07-2008, 17:33   #11 (permalink)
Member: 130995
Hello,
Yes, Mr. Akili Bulent is right, if you have any problem with latest version you can use old version from support area /software/updates/archive folder
Old 11-13-2008, 13:24   #12 (permalink)
Member: 75838
Thanks Meter: 67
thanks akil bulent my problem is solved. i restore handset with PANA01. V1.50
Originally Posted by InfinitySupport View Post
Hello,
Old 11-13-2008, 16:26   #13 (permalink)
Member: 130995
Hello,
Pana01 v1.54 was uploaded in support area day ago, you can use latest software, bug fixed.
Old 11-14-2008, 09:18   #14 (permalink)
gesundheit's Avatar
Member: 17851
Thanks Meter: 151
COM4 [VCP5] selected
module v1.54
Device: LG-KE970
Checking data, wait...
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 02
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0089:88B0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-sta...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta_20081114-154750.B1E.bin
reading eeprom-sta2...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta2_20081114-154753.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading eeprom-sec_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sec_35030526000000100_20081114-154756.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20081114-154801.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 0194
Done
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 31 sec
Remove/Install battery now !
mine's done. thanks infinity.
The Following User Says Thank You to gesundheit For This Useful Post:
Old 11-14-2008, 16:32   #15 (permalink)
Member: 130995
Hello,
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
ke970 error on boot rannie Infinity-Box 1 01-25-2010 15:45
KE970 error flashing jepetu Infinity-Box 7 04-17-2009 11:34
ke970 error while flashing... levetmar VygisToolbox 2 03-12-2008 09:24
KE970 unlocking error usernome FuriousGold 15 09-28-2007 13:25
Page generated in 0.23309 seconds with 10 queries
