04-07-2009, 09:26 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 200548 Status: Offline Thanks Meter: 104 | lg ke970 unlocking sucessfull module v1.65 Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20090407-135314.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20090407-135315.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20090407-135317.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20090407-135321.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 010A Done probably you need to restore original imei after unlock process Write Done Finished, time used: 29 sec Remove/Install battery now ! thanx infinity team again |
The Following User Says Thank You to bittubansal For This Useful Post: |
04-07-2009, 19:23 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
Lg KP235 unlock sucessfull by Infinity! | aikonmani | Infinity-Box | 17 | 09-21-2012 14:10 |
FOMA LG - L03A unlocked sucessfull HERE | csdd | VygisToolbox | 2 | 08-06-2010 12:28 |
lg ke970 unlocking sucessfull again | bittubansal | Infinity-Box | 1 | 04-18-2009 20:10 |
Lg KP100 unlocked sucessfull by n-box | randr | LG | 0 | 09-13-2008 09:59 |
lg KE970 unlock problem | oss001 | LG | 1 | 12-24-2007 12:48 |
