02-13-2010, 13:08 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | LG KG 290 Imei change problem please help ==== log: [2/13/2010 3:25:39 PM] ==== COM4 [VCP0] selected module v1.39 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 351955485698567 file saved: C:\Program Files\InfinityBox\LGA\eeprom_351955485698567_LG-KG290_20100213-152602.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... current eeprom imei: 351955485698567 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 32 sec Remove/Install battery now ! |
02-13-2010, 13:56 | #3 (permalink) |
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | I reset the set, then again write new imei but its failed. here is log COM4 [VCP0] selected module v1.39 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 357456017357412 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017357412_LG-KG290_20100213-175403.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... current eeprom imei: 357456017357412 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... error: no any expected answer error: flash write error: 01000000:00008000 error: no any expected answer error: flash write error: 01000000:00008000 error: errorcode#25 Write Fail Finished, time used: 81 sec Remove/Install battery now ! |
02-13-2010, 14:10 | #4 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | i think two days ago i did one with infinity , and its done , is your battery fully charged ? and your connection is stable Br Faisal_Computer |
02-13-2010, 14:23 | #5 (permalink) |
Member: 763332 Status: Offline Sonork: rashid Thanks Meter: 3 | yes, battery is charged, and if something wrong with my connection , then how i first change imei fully successfully. now i tried again and its done infinity write the imei. but when i check the mobile, mobile have old imei. that infinity shows that imei changed, but mobile did not. here is new log ==== log: [2/13/2010 6:00:15 PM] ==== COM4 [VCP0] selected module v1.39 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 357456017357412 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017357412_LG-KG290_20100213-180035.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... current eeprom imei: 357456017357412 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 23 sec Remove/Install battery now ! |
LG KG 290 flash done and imei is that ++4++44+5000 | Master Software | HWK | 2 | 01-30-2010 11:04 |
lg kg 290 problem after change imei | prime_master786 | Infinity-Box | 4 | 03-06-2009 15:29 |
lg kg 290 problem after change imei | prime_master786 | HWK | 1 | 03-05-2009 18:10 |
LG KG800 imei change problem.. need help pls. | bakhshalvi007 | HWK | 4 | 04-28-2007 21:32 |
LG KG800 imei change problem.. need help pls. | bakhshalvi007 | LG | 0 | 02-15-2007 09:18 |
