05-24-2008, 07:04 | #1 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 755760 Status: Offline Sonork: 852014 Thanks Meter: 11 | lg kg110 call drop problem i have one set lg kg110 problem is that when i call display show call drop when i dail *#06# display show 05000 i reboot ime,whrite eeprom,whrite ime but no respons COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done current otp imei: 000000000000040 Check flash... current eeprom imei: 354701011848764 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35470101184876 4_LG KG110_20080524-112207.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space... current eeprom imei: 354701011848764 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 35 sec Remove/Install battery now ! plz help me |
The Following User Says Thank You to piyushgsm For This Useful Post: |
05-24-2008, 07:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | If imei is ok and your sim card working in other phones then use FORMAT FFS.Even resetting the phone using 2945#*# will solve the problem bro. |
05-24-2008, 07:30 | #3 (permalink) |
Freak Poster Join Date: Apr 2006 Location: india
Member: 254397 Status: Offline Thanks Meter: 224 | Flash with this file & post here result KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M ..::Ricky Rayya::.. |
The Following User Says Thank You to .::ricky rayya::. For This Useful Post: |
05-24-2008, 08:47 | #7 (permalink) |
Member: 755760 Status: Offline Sonork: 852014 Thanks Meter: 11 | thanks sir lg k110 set is ok by flash with [ KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M ] this file |
lg kg110 call end dropped | Imrankhan | Infinity-Box | 24 | 12-14-2010 12:08 |
LG kg110 call drop problem | navin71 | LG | 10 | 06-08-2008 07:51 |
LG KG110 Call Drop........ | dil_PAKISTANI | Infinity-Box | 3 | 02-22-2008 07:28 |
Lg 2060 Call Drop Problem | vikash_@143 | LG | 0 | 02-22-2008 07:27 |
kg110 call drop problem | .::ricky rayya::. | Infinity-Box | 2 | 08-02-2007 20:22 |
