07-20-2009, 07:43 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Location: in hope Age: 49
Member: 77570 Status: Offline Thanks Meter: 17 | lg kg110 fail to write imei registraion failed to any sim lg kg110 failed to write imei phone show ###000 instead of imei by check code *#06# action taken write imei and formate also logs attach VCP0] selected module v1.38 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352691012669867 current otp imei: 352691010248867 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691012669867_LG-KG110_20090720-120323.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space ... current eeprom imei: 352691012669867 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 45 sec Remove/Install battery now ! |
07-20-2009, 08:10 | #2 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | do reset settings ....write eeprom from support and then write ime of ur own choice then sp unlock ur phone remember one thing use latest module pack for LgA br azeem |
The Following User Says Thank You to azeem781986 For This Useful Post: |
07-20-2009, 23:46 | #3 (permalink) | |
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Repair_imei_LG-KG110.txt | |
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 15:17 |
X480 Failed To Write Imei????????? | GSMLover2010 | NSPRO | 9 | 05-05-2008 10:05 |
X480 Failed To Write Imei????????? | GSMLover2010 | UST Pro II | 12 | 06-19-2007 13:13 |
Operation failed when trying to write imei on D720 | Burnt Cobba | NSPRO | 0 | 12-20-2006 00:34 |
