Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: INDIA
Member: 566051 Status: Offline Thanks Meter: 105 | Lg kg110 flashing ok but not boot |
![]() | #2 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | Plz supporte help me Flashing log here COM3 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 355995015245444 current otp imei: 352691018446831 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35599501524544 4_LG KG110_20080811-195759.B1E.bin ........ version: ***-XXV10hESAKG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1124 sec Remove/Install battery now ! |
![]() | #6 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | Sir I have new problem in this set.Set run properly ,network ok also.working good but within 2-4 minut restart again & again.Sim or without sim same restart.I reples other full flash but still.If I connect charger then not restart And working good.If I contineu any button then also working good.Plz help |
![]() | #8 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: india
Member: 588837 Status: Offline Thanks Meter: 146 | Quote:
![]() | #10 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | sir.Plz check log once more & tell me why are difrents both imei & how to repair imei...........................I think both imei are difrents so set restarting.......Thanks |
![]() | #11 (permalink) | |
Member: 566051 Status: Offline Thanks Meter: 105 | Quote:
COM3 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 355995016533764 current otp imei: 352691018446831 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35599501653376 4_LG KG110_20080812-112227.B1E.bin ........ version: 404-XXV10j91KG110P40FL Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1298 sec Remove/Install battery now ! | |
![]() | #13 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | put *#06# show on screen imei is 352691010123453 & back cover imei is 35599501524544 ..........................I think i should change imei but i can not do yet.Plz tell me how to change imei.Thanks in advance. |
N 6630 Flashing Ok But Not Boot Only White Screen | umesh garg | MT-BOX | 5 | 10-12-2011 07:21 |
Lg kg110 flashing ok but not boot | umesh garg | LG Hardware Repair | 4 | 08-13-2008 14:37 |
pinout search ok but not boot & read in spd cpu | kalpeshoza | SpiderMan | 7 | 06-05-2008 12:54 |
1110 1600 flash ok but not ok | SAN INFOTECH | Nokia Hardware & Hardware Repair | 0 | 09-17-2007 16:02 |
6600 dead, flash ok but not booting | syed.n | Nokia Hardware & Hardware Repair | 3 | 03-24-2007 21:46 |
