Lg kg110 unlock done USE CABLE LG 7050 COM7 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352691019041250 current otp imei: 352691019041250 file saved: C:\InfinityBox\LGA\eeprom_352691019041250_LG-KG110_20120403-001228.B1E.bin ........ version: 404-XXV20b91KG110P40FL Check flash Done Check space ... current eeprom imei: 352691019041250 ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 46 sec Remove/Install battery now ! |
hello! thank you for posting this positive report! |
