05-14-2009, 13:27 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | LG kg200 when i use cabel no proper work see this errer and help me uegent see pinout: 4:gnd 3hone rx(rj45 pin 2) 2hone tx(rj45 pin3) COM4 [VCP0] selected module v2.58 Device: LG-KG200 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 4 sec Remove/Install battery now ! |
05-18-2009, 21:19 | #6 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
Lg Kg200 show only Lg logo... | adnon | SpiderMan | 3 | 03-26-2010 04:16 |
LG KG200 LG LOGO Diaplay Only then Off | ASHRIFF | Infinity-Box | 18 | 10-26-2008 15:14 |
LG KG200 and LG KG300 | adnanskyland | SpiderMan | 2 | 10-10-2008 16:13 |
LG KG200 off on LG startup logo | asad_nomy7 | Infinity-Box | 2 | 04-09-2008 18:45 |
How to Run .jad and .jar files on LG KG200? | umarriaz2k7 | LG | 0 | 02-26-2007 10:56 |
