12-09-2007, 08:16 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: island of the.. Age: 49
Member: 79995 Status: Offline Thanks Meter: 1 | LG KG270 No Power Action taken: I Flash it with Firmware, Language Pack, FFS-2/File System and EEprom taken from support site. Result: Still no power ReadFlash Log: COM14 [VCP1] selected Device: LG KG270 Checking data, wait... Action: read flash Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 ESA V10b XXX-XX Apr 17 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: D:\Original GSM Device\Infinity Box\flash files\LG\KG270\Repair eeprom\backup_eeprom-sta_20071209-143607.B1E.bin loading data... data loaded imei: ///////////////// Reading [eeprom-sec_/////////////////]... file saved: backup_eeprom-sec_/////////////////_20071209-143611.B1E.bin Reading [eeprom-dyn_/////////////////]... file saved: backup_eeprom-dyn_/////////////////_20071209-143613.B1E.bin backup critical area Done Check memory... Reading [flash]... file saved: D:\Original GSM Device\Infinity Box\flash files\LG\KG270\Repair eeprom\backup_flash_20071209-144301.B1X.bin Completed Finished, Remove/Install battery now ! Time used: 1049 sec Please tell me what to do next. Thanks! |
12-09-2007, 10:39 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Morocco in my shop Age: 40
Member: 179651 Status: Offline Thanks Meter: 92 | BUT IN THIS ACTION U ARE READING FLASHE NOT WRITING FLASHE JUST WRITING FLASHE TO YOUR MOBILE ( KG270 P16 ESA V10b XXX-XX Apr 17 2007 ) AND AFTER FINISH WAIT ONE MINUTE AND ENJOY GOOD LUCK |
12-10-2007, 07:50 | #3 (permalink) |
Member: 79995 Status: Offline Thanks Meter: 1 | I flash it with Firmware and Language pack but still no power COM14 [VCP0] selected Device: LG KG270 Checking data, wait... Action: flash write Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 ESA V10b XXX-XX Apr 17 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20071210-144021.B1E.bin loading data... data loaded imei: ///////////////// Reading [eeprom-sec_/////////////////]... file saved: backup_eeprom-sec_/////////////////_20071210-144024.B1E.bin Reading [eeprom-dyn_/////////////////]... file saved: backup_eeprom-dyn_/////////////////_20071210-144026.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Write Done Finished, Remove/Install battery now ! Time used: 418 sec |
12-10-2007, 08:24 | #4 (permalink) |
Member: 79995 Status: Offline Thanks Meter: 1 | Flash it with Firmware+Language Pack+File system+eeprom but still no power COM14 [VCP0] selected Device: LG KG270 Checking data, wait... Action: flash write Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 ESA V10b XXX-XX Apr 17 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: D:\Original GSM Device\Infinity Box\flash files\LG\KG270\Repair eeprom\backup_eeprom-sta_20071210-150100.B1E.bin loading data... data loaded imei: ///////////////// Reading [eeprom-sec_/////////////////]... file saved: backup_eeprom-sec_/////////////////_20071210-150104.B1E.bin Reading [eeprom-dyn_/////////////////]... file saved: backup_eeprom-dyn_/////////////////_20071210-150106.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 457 sec Reset to Default COM14 [VCP0] selected Device: LG KG270 Checking data, wait... Action: reset Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 ESA V10b XXX-XX Apr 17 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: D:\Original GSM Device\Infinity Box\flash files\LG\KG270\Repair eeprom\backup_eeprom-sta_20071210-152510.B1E.bin loading data... data loaded imei: ///////////////// Reading [eeprom-sec_/////////////////]... file saved: backup_eeprom-sec_/////////////////_20071210-152527.B1E.bin Reading [eeprom-dyn_/////////////////]... file saved: backup_eeprom-dyn_/////////////////_20071210-152529.B1E.bin backup critical area Done Check memory... Check memory Done Write... Write Done Finished, Remove/Install battery now ! Time used: 38 sec Unlock COM14 [VCP0] selected Device: LG KG270 Checking data, wait... Action: unlock read unlock codes Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 ESA V10b XXX-XX Apr 17 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: D:\Original GSM Device\Infinity Box\flash files\LG\KG270\Repair eeprom\backup_eeprom-sta_20071210-152828.B1E.bin loading data... data loaded imei: ///////////////// Reading [eeprom-sec_/////////////////]... file saved: backup_eeprom-sec_/////////////////_20071210-152833.B1E.bin Reading [eeprom-dyn_/////////////////]... file saved: backup_eeprom-dyn_/////////////////_20071210-152834.B1E.bin backup critical area Done Check memory... loading data... data loaded code: //////// code: //////////////// Finished, Remove/Install battery now ! Time used: 20 sec Still no power. Maybe Hardware Problem? |
lg kp 501 no power | lusomaco | LG Hardware Repair | 1 | 03-31-2010 12:44 |
LG vx9800 no power after upgrade whit LGNSPT | verdugo | LG Hardware Repair | 3 | 11-23-2009 06:27 |
How Repair LG KG270 No Service | aswancamel | Infinity-Box | 1 | 08-04-2009 18:45 |
lg 8360 no power off | Pirex | LG | 0 | 11-07-2006 09:11 |
Lg 8138 No Power | S.SHANTHIKUMAR | Cruiser Suite | 1 | 03-04-2006 06:58 |
