11-26-2009, 06:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ONLY PRIVATE MSG
Member: 220932 Status: Offline Sonork: 100.1592154 Thanks Meter: 110 | lg kg300 flashing problam log OM5 [VCP1] selected module v2.96 Device: LG-KG300 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware KG300P64-ARB-V10e-000-00 FEB-06-2007_ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7312SA00-001-R1C_En_Ar_Fr_Ru.A3M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 00315C1:16BE status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:76737200000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning ffs address can not be detected, value from database assigned: 00000000/00000001 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Fail Finished, time used: 17 sec Remove/Install battery now ! |
lg kg300 problam | janki_amreli | Infinity-Box | 3 | 06-10-2009 10:30 |
lg ku990 flash problam | newerno | FuriousGold | 4 | 11-02-2008 10:21 |
LG KG300 Flashing help .. :( | Software-Zone | Infinity-Box | 5 | 11-05-2007 14:19 |
Lg KG300 dead after flash | d14n | Infinity-Box | 43 | 11-04-2007 13:17 |
Need Lg Kg300 Flashing Cable Pin Out | wazir | LG | 0 | 08-17-2007 14:14 |
