11-12-2008, 19:09 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | -: Lg kg300 restart prob solv by infinity :- HEAR IS LOG:- ==== log: [11/12/2008 11:16:23 PM] ==== COM4 [VCP0] selected module v2.40 Action: reset settings Model: LG-KG300 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:98416A0 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7315IN00-001-R1F Version: EP1 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 219 warning: wrong packet cs warning: wrong packet cs 219 of 219 items cleared building list... done 0 items remains Finished, time used: 43 sec Remove/Install battery now !====== THEN I PUT WRIGHT IMEI . LOG:=== Action: imei Model: LG-KG300 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6227, E02 Hardware version: EP1 Software version: 7S7315IN00-001-R1F" Software date: 2005.04.12 Barcode: AT+EGMR=0,5 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 3528XXXXXXXXXX verification Ok Finished, time used: 69 sec Power off phone now ! FIRST I READ FULL FLASH: HEAR IS LOG:=== COM4 [VCP0] selected module v2.40 Device: LG-KG300 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:98416A0 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1F.BIN ver. sw 2: 7S7315IN00-001-R1F, 00000000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1F.BIN]_part_1_of_1... file saved: C:\Program Files\InfinityBox\MModule\flash[ARIMA27_05C_PCB01_GPRS_MT6227_S01.7S7315IN00-001-R1F.BIN]_part_1_of_1_20081112-230820.A3X.bin Finished, time used: 2177 sec Remove/Install battery now ! |
The Following User Says Thank You to debmobile For This Useful Post: |
11-12-2008, 19:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-13-2008, 14:26 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | Thanks support Realy it works (format whole flash chip in chinies miracle selecting nand) thanks very much infinty team you are great |
Vodafone 125 Restart Problem Solved By Infinity | zeel_zeel | Infinity-Box | 4 | 07-23-2010 08:25 |
LG KG300 Restart Problem! | Was33m | LG | 13 | 12-13-2008 06:44 |
lg kg300 restarting solved with format also pinfinding with pinfinder | joni_rajpura | Infinity-Box | 3 | 12-09-2008 14:01 |
Lg Kg300 Restart | alfin5557 | Infinity-Box | 15 | 08-15-2008 13:06 |
LG KG300 Restart Problem | Miftahudin | Infinity-Box | 3 | 09-25-2007 18:51 |
