Old 07-19-2009, 19:46   #1 (permalink)
Member: 491880
Sonork: 1620586
Thanks Meter: 9
Lg-kp-115 which cable to use for flash
I HAVE INFINITY AUTO PIN FINDER WITH ALL CABLES ,I WANT TO FLASH LG-KP115 BUT I AM CONFUSED PLEASE HELP ME TO CHOOSE THE CABLE CORRECTLY,INFINITY TEAM HELP...
Old 07-19-2009, 23:40   #2 (permalink)
communication_expert's Avatar
Member: 50511
Sonork: 100.109684
Thanks Meter: 307
KE500 cable must be used with KP-115 phone
Old 07-19-2009, 23:42   #3 (permalink)
Member: 50511
Sonork: 100.109684
Thanks Meter: 307
LG PHONES CABLE PINOUTS
KF240,KF245,KF300 pinout
keybord up
18.............1
17 - RX (data to phone)
16 - TX (data from phone)
11 - PWRON connected via 47 kOm resistor to +5V
1,4,14,18 - GND
KP110,KP115,KP130,KP210,KP215,KP 230,KP235 pinout
keybord up
18.............1
1,4,14,18 - GND
CG180 pinout
keybord up
18.............1
1,4,14,18 - GND
LG240,ME240q pinout
For flashing-unlocking - use U8110 cable.
For working with service functions-Read IMEI,Write IMEI, Phone Reset - use
LG7050 cable.
KE500,ME550 pinout for flashing
keybord up
18.............1
1,4,14,18 - GND
For working with service functions -Read IMEI,Write IMEI, Phone Reset - use
KG800 cable.
G1800 pinout
Use standart Motorola T191 Cable
KG190,C2500 pinout
keyboard up
/12345\
_______
1 - GND
3 - TX (data from phone)
4 - RX (data to phone)
MG160,KG270,KG370,KG320,KG800 pinout
keybord up
18.............1
1,4,14,18 - GND
C1100,C1200,C1300,C1400,LG40xx,LG70XX,L11XX pinout
keybord up
24.............1
3,12,19,23 - GND
13 - RX (data to phone)
14 - TX (data from phone)
6 - via 10 kOm resistor to +5V
LG G510,B1300,G1500,3000,5200,5300,5400,7100,7070 pinout
keybord up
18.............1
2 - RX (data to phone)
3 - TX (data from phone),connect it via resistor 15 kOm to +5V
1,13 - GND
15 and 18 connect together
LG-U8110,U8120 pinout
keybord up
24.............1
12,19 - GND
18 - TX (data from phone)
2 and 21 connect together
Code to reset phone(must be used if after unlocking phone still is locked or has user code) : 2945#*# and later "Factory reset".
b.r.
Old 07-20-2009, 23:51   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 07-31-2009, 14:33   #5 (permalink)
SOFT GSM's Avatar
Member: 218791
Thanks Meter: 35
what about lg kf245 unlock supported by infinity or not yet?
thnks
Old 04-13-2012, 07:29   #6 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
i need lg kp115 pinout
Old 04-13-2012, 21:40   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
which connector type is used? can you post picture of test points?
Which cable to use for flash or unlock this tv phone Shantobhai Infinity-Box 4 07-24-2009 15:45
M620 which cable to use for flash whith ustpro2? Shantobhai UST Pro II 7 07-09-2009 09:07
LG G7100 - What cable to use for flash? Dirdan LG 4 04-01-2006 11:27
Can u tell me which cable to use for flashing DCT3 Nokia 6250 mohd_anan Nokia Hardware & Hardware Repair 7 07-21-2004 08:28
which cable to use for nokia 6610 same as 7210 monti_908 Nokia Digital Core Technology 4 ( DCT-4 ) 1 02-06-2003 09:58
Page generated in 0.28536 seconds with 9 queries
