01-31-2009, 11:29 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: WITH SOME SELFISH PEOPLE
Member: 294880 Status: Offline Sonork: 100.1587133 Thanks Meter: 132 | ******lg kp 130 successfully repaired COM21 [VCP0] selected module v1.36 Device: LG-KP130 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 352126022495623 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352126022495623_LG-KP130_20090131-151537.B1E.bin ........ version: - reading -_eeprom-ffs_352126022495623... warning: wrong data size at 0x18609000, retry... read error recovered warning: wrong cs at 0x186A5800, retry... read error recovered warning: wrong cs at 0x186C1800, retry... read error recovered warning: wrong cs at 0x186DC000, retry... read error recovered warning: wrong cs at 0x18722000, retry... read error recovered warning: wrong cs at 0x18737000, retry... read error recovered warning: wrong cs at 0x1874EC00, retry... read error recovered warning: wrong cs at 0x1875C000, retry... read error recovered file saved: C:\Program Files\InfinityBox\LGA\-_eeprom-ffs_352126022495623_LG-KP130_20090131-152014.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 352 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to saqibmalik For This Useful Post: |
01-31-2009, 11:40 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Lg Kp 130 How To Unlock? | denard | HWK | 13 | 10-02-2008 13:13 |
KP 130 problem in unlcok | hicvb7 | FuriousGold | 12 | 08-06-2008 15:08 |
Kp 130 Successfully Unlocked | ..::Mobile Smoker::.. | VygisToolbox | 0 | 08-05-2008 19:03 |
Kp 130 Unlock ............... | multicom_fsdpk | Infinity-Box | 5 | 06-20-2008 10:17 |
kp 130 how? | zulu land | Infinity-Box | 13 | 06-19-2008 19:39 |
