08-12-2008, 08:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | LG KP100 Unlock OK but Method #2 does ---------------------------------------------------------------- COM4 [VCP0] selected Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 MAR-0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20080812-121802.B1E.bin loading data... data loaded imei: 359961019358***xx reading [eeprom-sec_359961019358***xx]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_359961019358***xx_20080812-121803.B1E.bin reading [eeprom-complete_35996101935852200]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35996101935***xx_20080812-121806.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 19 sec ----------------------------------------------------------------- |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
LG KP100 Unlock | h4mza | LG | 8 | 07-03-2011 01:51 |
KP100 unlock ok | youssef70 | Infinity-Box | 1 | 10-05-2008 18:10 |
lg kp100 unlock | newerno | Infinity-Box | 10 | 09-12-2008 09:26 |
LG KP100 unlock problem | msashami | Infinity-Box | 1 | 09-02-2008 12:04 |
Kp100 unlock ok VIA Kg375 | abumu3ed | Multi-Box | 11 | 07-24-2008 05:05 |
