02-21-2008, 19:52 | #1 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: Moon Age: 43
Member: 55717 Status: Offline Thanks Meter: 47 | LG KP106b (LG RUBY)- Claro Provider - unlock is possible??? I have 7 pcs of this phone, it's a chipset Infineon, much seemed as MG160. Difference - FM radio. But, phone dont show "insert unlock code" menu after "insert correct sim". Maybe phone is permanent locked. See log file: Model used: MG160 COM2 [VCP0] selected Device: LG MG161 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL BRAZIL CLARO KP106b 01 FL 55 V10a 724-05 DEC-03-2007 + Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Arquivos de programas\InfinityBox\Pana01\backup_eeprom-sta_20080221-152638.B1E.bin loading data... data loaded imei: 35213102030264900 reading [eeprom-sec_35213102030264900]... file saved: C:\Arquivos de programas\InfinityBox\Pana01\backup_eeprom-sec_35213102030264900_20080221-152640.B1E.bin reading [eeprom-complete_35213102030264900]... file saved: C:\Arquivos de programas\InfinityBox\Pana01\backup_eeprom-complete_35213102030264900_20080221-152643.B1E.bin reading [eeprom-dyn_35213102030264900]... file saved: C:\Arquivos de programas\InfinityBox\Pana01\backup_eeprom-dyn_35213102030264900_20080221-152644.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 91688534 Finished, Remove/Install battery now ! Time used: 19 sec I read backup of phone, If possible I send it now to [email protected] Quote:
BR. | |
The Following 2 Users Say Thank You to JoAoOpAuLo For This Useful Post: |
02-21-2008, 21:02 | #3 (permalink) | |||
Member: 55717 Status: Offline Thanks Meter: 47 | Quote:
Tried read codes; Tried direct unlock method #1 and # 2 (Airtel, etc.) Don"t unlock. BR. Quote:
02-22-2008, 09:35 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to flash phone with MG160 flash files, let's see results. KP106 files uploaded in support area so you can restore phone in it's original state in case of any problems. |
03-13-2008, 23:38 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @gsm_unlock2 1. Please, make full flash backup from your phone, please send it to [email protected] 2. Try to flash phone with MG160 flash files 3. unlock phone Let's see results. KP106 files uploaded in support area so you can restore phone in it's original state in case of any problems. |
09-22-2009, 17:54 | #8 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: INDIA Age: 39
Member: 737827 Status: Offline Sonork: 1589375:siraj Thanks Meter: 49 | Quote:
thakssssssssss brooooooooo | |
09-23-2009, 09:18 | #9 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 50
Member: 90058 Status: Offline Thanks Meter: 97 | first to flash phone with MG160 flash files 2 unlock phone by code 3 power on the phone show low contrast dont worry insert sim and enter code thats all next 4 reflash kp 160 flash file and insert sim and use i done today this step |
09-23-2009, 09:19 | #10 (permalink) |
Member: 90058 Status: Offline Thanks Meter: 97 | solved first to flash phone with MG160 flash files 2 unlock phone by code 3 power on the phone show low contrast dont worry insert sim and enter code thats all next 4 reflash kp 160 flash file and insert sim and use i done today this step |
09-15-2010, 06:58 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | witch files you have used ...........i have also flashed kp106b with mg160 only firmware file and after flash try to unlock by read code but same error as kp106b before |
Unlock Lg Ms25 unlock is possible? | evaca26 | VygisToolbox | 2 | 03-24-2009 16:52 |
Lg C1500 Unlocking Is Possible With Multi Box Lite? | sairat | Multi-box LITE | 0 | 01-20-2008 18:29 |
!!!! CXx70 unlock is possible !!!! | davidoffman | Siemens-Benq RingTones and WallPapers | 1 | 02-01-2005 01:32 |
3310 unlock ?! is possible | KomeT | Phone Unlocking Codes & Maps | 2 | 12-16-2003 16:51 |
