LG KP230 -> error: hardware is not supported, errorcode#01 COM6 [VCP0] selected Device: LG-KP230 Checking data, wait... advanced flash detection active Action: unlock unlock method: enhanced Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: 89881600010001:89881600000000 id: 00005258 error: hardware is not supported, errorcode#01 Boot Fail Finished, time used: 16 sec Remove/Install battery now ! |
Hello, Please, download and install latest LgA update from Infinity-Box support area. http:///vbb/showthread.php?t=587759 |
downloaded and instaled, but same problem |
not suppported this phone all versions |
bro use PL-2303 usb to com and post results BR MAPLE GSM(UMER) |
Hello, Please, use LgA module v1.32 from support area. |
i could not understand ur post?? |
@Shakeel_pattoki It was an advice to use another cable type (cabled based on PL2303 USB-RS232 converter). |
i have same prblem COM5 [VCP0] selected module v1.39 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 00880EFFDFFFDF:00880E00000000 flash: 00880EFFDFFFDF:DEEA0000000000 id: 00005283 error: hardware is not supported: errorcode#01 Boot Fail Finished, time used: 5 sec Remove/Install battery now ! |
i have installed 1.39 v also,, but same |
What is the problem with your phone ? Is it good working or dead phone ? I think your phone is dead and you can not flash it. If phone is dead you must check phone hardware due to it looks like hardware is damaged. |
yes. my handset is dead sir,, ok, i will in hardware |
