Old 10-08-2008, 15:22   #1 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
need pinout for 6300 with samsung 18 pin connector
hi
i need tested pinout for this nokia 6300
please help asap.
Old 10-08-2008, 15:24   #2 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 664
Originally Posted by wolf_dz View Post
hi
please help asap.
me to need pinout of this modal.
Old 10-09-2008, 10:35   #3 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
help please.......... !!!!
Old 10-09-2008, 10:57   #4 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Try these points one by one with some Pin Finder. For example SpiderMan,PAD Finder or Infinity Pin Finder.
I am sure that some secret is hidden within these poinits.
BEST OF LUCK
yawarniazi
Old 10-09-2008, 11:09   #5 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
offcourse rx and tx must be within this pin but
i havnt any pad finder right now,
Old 10-09-2008, 22:26   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you can test this test points with multimeter too.
i can teach how
Old 10-10-2008, 16:33   #7 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
OK lets see
if i follewed this guide:
http:///vbb/showthread.php?t=433447
can i use immidiately the pcb gnd as gnd / or use the batterie (-) pin as gnd. and jump to step2.
in step: 2 may i powered the pcb by power suply ? power on the phone or not ?
thanks in advance
Old 10-10-2008, 17:57   #8 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
@wolf dz
u can use multimeter seek for 2.74 v on this test point that's all u must find tow point tike 2.74 v one rx and second tx gnd any place - on pcb
wbr
The Following User Says Thank You to freeman2001 For This Useful Post:
Old 10-10-2008, 18:05   #9 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi all..
u r sure that phone hasnt spreatrum cpu..? i cant read the chracters on the cpu...it loooks like spreadtrum cpu...cause of one cpu and 2 imei.. but maybe..maybe it can be mtk too...
b.r..
The Following User Says Thank You to LoveLess For This Useful Post:
Old 10-10-2008, 21:00   #10 (permalink)
Member: 148515
hello!
please let us know your CPU type.
also: using power supply for pinout detection will give incorrect voltage values.
so please use good charged battery instead
Old 10-10-2008, 21:13   #11 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
thanks to Freeman and loveless and InfinityHelp
cpu: SPREADTRUM- sc660QD5-180G
q? may i need to power on the phone or can do the operation with off phone.
Old 10-10-2008, 21:17   #12 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
pinfinder can find the pinouts.. if u havent it i can add for u.. what is u r pb with ur phone..? why do u need pinout..?
Old 10-10-2008, 22:02   #13 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
i havnt pinfinder.
i need to format this phone because it hang at startup screen.
phone not water damaged.
Old 10-10-2008, 22:23   #14 (permalink)
Member: 206476
Thanks Meter: 459
just u need his original usb cable power the phone without sim pc detcte new hw install his driver and read documontaion on C:\Program Files\InfinityBox\SPD2\UserManual
wbr
Old 10-10-2008, 22:38   #15 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
i havnt pinfinder.
infinty cant help u...cause they not supported spd format.. but u can use other tools...
Cect U90 18 pin connector pinout here techie786 Infinity-Box 1 02-03-2009 17:53
hi i need pinout for 6300 (7 pins) faisal butt J.A.F. By Jafsupport.com 8 12-16-2008 12:16
Need Samsung full 18 pins connector for NEC phone. LarryA NEC 1 08-10-2008 06:53
Pinout For Nokia N95 2 Sim 18 pin connector MarvelXZ Infinity-Box 1 02-26-2008 00:31
N95s dual sim 18 pin connector pinout .::Zafar Communication::. Infinity-Box 2 06-12-2007 20:34
Page generated in 0.25060 seconds with 10 queries
